[IGN-2046, IGN-8730] Perspective Numeric text field
Hello folks,
I find the behavior of the numeric text field a bit... funky. Especially when it doesn't have a value.
Right now, the default empty value is nothing. Which is interpreted as an empty string.
This makes a 0 appear in the field instead of the placeholder.
The only way I found to make the placeholder appear is to set value to null, which makes this appear:
I, and I suspect many people around here, don't like red triangles.
And even if you ignore this error and use null as a default, if a user enters a value then deletes it, it goes to an empty string.
The whole thing makes doing calculations based on several numeric entry fields quite an exhausting exercise:
Before values are entered, you're dealing with nulls (if you want the placeholder), which is fine, but then you also have to handle strings in case the users delete their input. And the placeholder never comes back, a 0 is displayed - which makes the users think they actually have a 0 there.
I guess the tl;dr is this: please make the empty value of the numeric field a null.
Now I understand this would break things for projects handling empty strings, so I really have no idea what can be done, but frankly, I needed to rant about this.
i have this problem as well, the numericEntry show 0 value instead of place holder.. any solution yet ?
The only way is to monitor the value property and check for empty strings, in which case you need to set it to null.
The whole thing is a pain in the ass, hence the improvement request.
A workaround that I can think of is using a property change script on the value property to change it to a null value whenever theres an empty string.
Before I begin, I want to be clear that I agree with you and that I raised this very issue during the Alpha phase of Perspective. It's been so long now that I can't recall the reasoning for why we chose the direction we did.
Unfortunately, I believe we're more or less "stuck" with the current behavior because there's an excellent chance that users have implemented project behaviors around what we have documented as this expected behavior. If we were to change the default value for a Numeric Entry Field (NEF) to be null, there are two approaches we would conceivably follow:
  1. ALL NEF (old and new) components now load up with null as their default value if no value is supplied/stored in configs. This breaks existing project logic which expects empty strings. The end result is users now reporting broken project logic to support because that project logic was based on documented behaviors.
  2. Only NEWLY PLACED NEF components default to null when there is no configured/stored value. This is less likely to break existing project logic, but now you have one component with two different behaviors; old NEFs display 0, and new NEFs display nothing. If a View has both, does a 0 truly convey 0?
I suppose it could be new component ("alternate numeric field" or similar) with the default null. Are there any other outstanding issues with numeric fields that cannot be fixed for backward compatibility reasons?
2b. add a property to the NEF, maybe a boolean, that allows switching from one behavior to the other, so that we can 'convert' old style NEFs to the new style by just checking a box ?
This doesn't fix the 0/null inconsistency, but it makes switching to the new behavior quite easy, and leaves the task of making things coherent to the integrator - which is part of his job anyway.
Or... We could just update the schema warning to allow for null.
That would actually be a good start, but it's a cosmetic fix. It doesn't help with the value resetting to a blank string when the user removes the number, which wouldn't be that bad if it didn't make the field display 0...
How about making the empty string not display 0, but the placeholder instead ?
That shouldn't break anything.
I'll run that by the relevant internal parties.
It turns out we already have an open ticket to improve the placeholder usage around empty strings, so these two tickets in tandem should alleviate all of your concerns.
That's great, thanks a lot !
I found a work-around to have the numeric entry component display nothing when the props.value field is empty.... and that's by setting the props.format field to an empty string (i.e., '').
I actually use some logic on the props.format field to either return an empty string if the value field is empty or the desired format if there's a valid number in the value field.
try:
	float(str(data))
	return '(0,0.##)'
except:
	return ''
Clever!
I had this same issue for a long time. The best solution that I have found to resolve this issue was to set the value to "=None" so it looks like the following: self.props.value=None
Doing this allowed me to clear the value of the component and get the placeholder text to show. I set my clear command up on a message so I could clear multiple fields at once.
Works perfectly in my application, as well. Thank you!
Hello there,
Any news about this ?
While it somehow was left out of the 8.3 changelogs, this issue was resolved as part of the upcoming 8.3.3 release. Please consider using a nightly build to see if the changes meet your needs in your projects.
Great, thanks !
