[IGN-4005]Just one of those moments
>>> hist_col_names = hist_dset.getColumnNames()
>>> new_dset = system.dataset.toDataSet(hist_col_names, new_data)
TypeError: toDataSet(): 1st arg can't be coerced to org.python.core.PySequence
C’mon, Ignition! You’re the one who gave me that list of column names, from a dataset, that you can’t use to set the column names of a new dataset unless I pass it through list() for you?
:exploding_head:
Boo, we’re doing something silly in the implementation. I added a note to fix this at the same time we rename the function toDataset.
Heh. I’m always typing that lowercase ‘s’ and then backing up. I’m sure I’ll keep backspacing long after I don’t need to.
