I have an SQL query where I want to replace stuff in a field’s text with {1}, however the query is thinking I have a tag/property called 1 and is then failing to replace it. How can I escape this behaviour? I’ve tried all the usual things like:
{{1}
\{1}
What have you tried, will this work…
query = '''
SELECT .... {0}.....{1)
'''.format(x1,x2)
Edit, I believe I misunderstood your question, but I’ll leave the post anyways.
This is unfortunately impossible (directly). Could you put the curly braces you need in a custom property, then reference that custom property as a property reference in the query?
I did kick the old ticket I filed back in my support days for this, which might help a bit…
I ended up just using square brackets instead. I didn’t really need to use braces, I just wanted to use familiar syntax e.g. as in indirect tag bindings.
Also, i must have rushed that post as I should have included an example query… It seems you understood it though, but here anyway:
SELECT REPLACE(field_name, 'thing', '{1}')
FROM table
