Some error shows on the log periodically. would someone see this before and know how it could be solved? Thanks.
java.sql.SQLNonTransientConnectionException: connection exception: closed
at org.hsqldb.jdbc.JDBCUtil.sqlException(Unknown Source)
at org.hsqldb.jdbc.JDBCPreparedStatement.(Unknown Source)
at org.hsqldb.jdbc.JDBCConnection.prepareStatement(Unknown Source)
at org.apache.commons.dbcp2.DelegatingConnection.prepareStatement(DelegatingConnection.java:301)
at com.inductiveautomation.ignition.gateway.localdb.DelegatingDataSource$DelegatingConnection.prepareStatement(DelegatingDataSource.java:281)
at com.inductiveautomation.ignition.gateway.history.stores.AbstractDatasourceStore.cleanupSchemas(AbstractDatasourceStore.java:462)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:582)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: org.hsqldb.HsqlException: connection exception: closed
at org.hsqldb.error.Error.error(Unknown Source)
at org.hsqldb.Session.execute(Unknown Source)
… 13 common frames omitted
