Ignition 8.1.18:
If I configure a tooltip on a Standard Tag (currently, “This is a tooltip!”), I am able to see the tooltip when hovering over a tag within the tag database:
However, if I configure a tooltip on a Data Type Instance (from UDT definition: “This is a UDT tooltip!”), I am unable to see the tooltip during hover:
End goal is to display the tag description, as-defined from a parameter configured in the UDT. Unsure if this is a bug, or if I need to configure a setting somewhere in order to see tooltips on UDTs. Any suggestions?
