That is why I did not recommend using an outer try, but to do error checking in the functions themselves.
This v8.1 workaround is not perfect, cannot be perfect, and will never be perfect. If you need this to be perfect, upgrade to v8.3.
I just installed v8.3.1 and turned off the workaround I had in place (i.e. a decorator on every custom class definition using a thread lock and cache stored in project globals to only allow one class definition to exist for each class).
Unfortunately, at least in the designer, I am seeing the same problems I was before. I have a class defined in one module which I import into multiple others, but for some reason the module with the class definition gets executed repeatedly and some callers end up with different class definitions than others. Maybe this is a separate issue from what @pturmel was talking about, but it remains a significant challenge to development in Ignition.
I wonder now that the race condition problem should be fixed with the import mechanism, if this is happening because imports are not exactly the same everywhere and whatever is being used as a primary key is different for the same code module depending on how the module is being imported/accessed.
__init__.py can work in python, where it imports from the modules inside the package, avoiding the need of the caller to import from each individual module. There are then imports inside shared._custom between modules as well as imports by external callers made using the custom public module.
shared/
_custom/
module_a
module_b
custom: import from shared.\_custom.module_a/b/c
Importing from project library scripts is known to cause problems. Instead of importing you should be using the full path/name of the resource you would normally import.
# Don't use import
from shared.x import y
# instead call it as
shared.x.y()
Thanks, @Clancy_Cavanaugh , that might work, but at this point I think I have a few hundred thousand lines of code. Updating every import statement in every script module/event script/tag script/etc. is not feasible for me at this point. If I were able to start fresh, that is definitely what I would try.
Probably still worth it to fix. Even if you put your decorator back in, you can run into issues with some running scripts using the old versions until they are reinitialized.
I believe I remember there being a memory leak possibility as well, but that may have only been if you are trying to persist something with system.util.getGlobals().
I would get cranking on refactoring your code. Importing project library scripts is known to be full of issues.
While I appreciate the flexibility of Ignition, from my personal perspective it has been challenging sometimes to discern what the "official" solution is from IA vs something which may work now but may also break in a future release. It would have helped me a great deal, coming from a Python background, to maybe have the video tutorials and documentation make mention of things which may not work as one might expect given that background. Specific mention of issues around custom classes, imports between scripting modules, and which libraries to use for handling different problems, might have helped in avoiding long-term growing pains.
Regarding libraries the consensus is
system.* namespaceGreat thread here too with a lot of good info Do's and Don'ts when developing First Project with Ignition?
There are definitely some areas in the docs and tutorials that actively promote bad habits. Binding full UDTs comes to mind.
There's another I saw from memory where tag values were being sent to a popup instead of the tag paths…
that would definitely confuse newbies when they try to go and write to them in the popup..
The content should need to go through a dev first, or an experienced set of eyes who has scada design experience, as that's the most relevant. Software application devs don't always have the experience to know what the end user wants or how they will use it. (Even scada devs don't always know exactly how the operators will break use the scada!)
So it's fixed but not really fixed? Or is it fixed when you import consistently around all your projects?
The race condition described in this topic (parallel initialization threads corrupting the script module) is fixed in v8.3. In v8.1, project library auto-import is unlocked. As noted above, the attempt to fix this with a script manager lock crashed and burned due to AB-BA deadlock with jython's own import lock.
The fix in v8.3 uses the jython import lock to also guard the library auto-importer. Adding a lock check to a previously unlocked fast path is a likely performance impact.
Note that the jython import statement always takes and then releases the import lock, every time it executes. This is the primary reason you should never place any import statement inside a function or method--you will have lock contention when busy. Ignition's auto-importer only takes that lock when necessary, IIUC. The auto-importer's fast path is also the reason you should never import from project library scripts at all--avoid lock contention on startup, too.
Ah ok, I'm not familiar with import locks or guards, but what I understand:
importing at the top of my script is always safe in 8.3?
If you mean the top of a project library script, yes. You should not use import anywhere in an event script.
Perfect, that is wonderful news to me!
Hi Phil, could you wrap the whole module code in a try and put that release in the finally? Or at least everything after those first lines
That breaks the function sidebar. As Lionel noted in comment #20.
We tend to take a similar approach and haven't ran into any issues. We have multiple scripts in our project library that are called on events or on startup scripts. We often instantiate variables and set them equal to 'None' and then let a function set their corresponding values when called. We haven't ran into any issues with this but we could be naive. I should note that the initialization of the project scripting library does not call any of our functions. Our functions are only called on events.
The reproducer I supplied does the same. The issue is that all defined gateway startup, timer, and tag change events are called at gateway startup, or project restart, in parallel (multiple threads). See comment #2 for guidance on when you should or should not use the work-around.
