When going to production we will be going to the latest version and the hardware will be licensed. We were concerned with the constant OPC UA Server faults and were considering different hardware if this couldn't be resolved. So it sounds like with this hardware setup and a license for Ignition Edge with MQTT Transmission we should be in the clear for production and won't expect any further faults?
I don't think you'll see this once you're licensed, no. You might try testing w/ Standard edition (using the same set of modules) where the trial reset shouldn't trigger restart of the OPC-UA module.
