Through recent discovery and working with Ignition support, we have found a bug in the Vision "Label" component (though it may already affect other text based components as well).
Using just about any font in the library, instantiate a Label component to the page, our example had the following settings:
"Verdana, Bold, 15"
The Label in its current form has no visual issues, but if you utilize the built in "Rotation" parameter to rotate beyond 0°, even only 1°, the font clarity, alignment and sizing is affected. See the following examples on a 1920x1080 dev screen:
The following Ignition Bug Ticket has been added to this item: IGN-7259
