[IGN-8563] Perspective Map customControls Bug?
I've created a view with a map component on it, and created a view that I want to use for the customControls property of the map. But when I put icons or buttons in the controls view, they don't show up on the map. I can put a label or something like that on the controls view, and it will show up on the map view. Just not an icon or a button. Any suggestions? I'm running version 8.1.32.
controls view
map view
You're absolutely right. I suspect we won't hold up the 8.1.33 release over this as you've already specified it was broken in a version before this upcoming release, but I'll make sure the fix is part of 8.1.34.
Ok, thank you.
Was this fix?, I'm having the same issue with 8.1.35
It had to be pushed to 8.1.36, but yes, it has been fixed.
