After loading resources from Ignition exchange to parent projects. All inheritance project unable to open from designer. Only project which not part of that parent project opened. Below is the error. Any guidance
IllegalArgumentException: com.inductiveautomation.ignition.common.project.resource.ResourceNamingException: Cannot add child 'com.inductiveautomation.perspective/style-classes/exchange/alarm-configurator' to parent 'com.inductiveautomation.perspective/style-classes/Exchange'
caused by ResourceNamingException: Cannot add child 'com.inductiveautomation.perspective/style-classes/exchange/alarm-configurator' to parent 'com.inductiveautomation.perspective/style-classes/Exchange'
Your child project contains a resource with a differently-cased name at the same level as a resource of the parent project. You need to go into the parent project and rename the resource, then go into the child project and rename THAT resource, then you can rename the parent back to what it was.
i did same and working fine .. My main question is i uploaded the resources to my parent project . Without any errors and even when i need to open the parent project i got the errors in parent project and also child project .
The file system belongs to the operating system - not the Gateway. References to file system mean opening up File Explorer, or Finder, or whatever tool/system your operating system uses to provide direct access to files. This is all moot though as you should be able to open a Designer to the parent project and resolve the issue by renaming the parent project resource, then renaming the child project resource, then renaming the parent project resource back to its original value.
The interesting part is that there is no parent project. I see the file path in the error - "Cannot add child 'ignition/script-python/BHEC/Network/Ping' to parent 'ignition/script-python/BHEC/network'"
Is it really just a matter of changing the case on the "n" in network?
There’s not exactly an underlying bug here, as this is an expected failure state. That being said, the logged error/exception is not as helpful as we would like. The internal ticket is not going to change this behavior other than to improve the logged exception with a recommendation to reach out to Support for assistance in resolving the issue. The improved logging should be available in nightly builds starting tomorrow, and will be part of the 8.3.6 release.
I solved this issue quickly by going to the gateway webpage, platform/system/projects, and clicking "scan filesystem now".
Not sure if this will solve all similar issues, but it worked for ignition edge 8.3.5. The issue was caused after I imported some older perspective components, which likely had the style-class with a conflicting name.
