Has anyone else noticed issues with the v2027.2.0-BETA1 Designer Launcher connecting to existing Ignition 8.1 gateways?
I installed the beta launcher to have a look at Ignition 2027, but since doing so I've been unable to launch designers from my 8.1 environments. The launcher repeatedly retries the connection and eventually reports the gateway as "Incompatible".
Environment:
Designer Launcher: v2027.2.0-BETA1
Gateway: Ignition 8.1.x
OS: Windows
Gateway is otherwise accessible via browser and functioning normally
Hopefully this is something that gets addressed before the official release. Having to constantly install and switch between two different versions of the Designer Launcher to work with 8.1 and 2027.2 gateways is going to be quite annoying.
My dilemma is that I've adopted the v8.3 shortcut system (abc.designer, def.vision, et cetera) which simplifies my actual launcher app lists. But I also love the scheme support for launching right from the gateway home page. Any dual install system that attempts to support v8.1 will have to give up 2027 shortcuts or the new shortcuts for v8.1. I may have to revert all my v8.1 shortcuts to v8.1 launcher style and re-bloat my launcher json. There's no simple solution.
