Ignition 7.5.5 : how to disable SSL for connection to Posgres 13?
I have an Ignition 7.5.5 (java 7) - JDBC Driver:postgresql-42.2.20.jre7.jar
Connection with Postgres 9 and Postgres 11 work fine.
I try to connect to Postgres 13 and I have the following error:
Cannot create PoolableConnectionFactory (SSL error: Received fatal alert: protocol_version)
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (SSL error: Received fatal alert: protocol_version)
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:194)
com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:150)
com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.run(DatasourceManagerImpl.java:1102)
java.lang.Thread.run(Unknown Source)
org.postgresql.util.PSQLException: SSL error: Received fatal alert: protocol_version
org.postgresql.ssl.MakeSSL.convert(MakeSSL.java:43)
org.postgresql.core.v3.ConnectionFactoryImpl.enableSSL(ConnectionFactoryImpl.java:534)
org.postgresql.core.v3.ConnectionFactoryImpl.tryConnect(ConnectionFactoryImpl.java:149)
org.postgresql.core.v3.ConnectionFactoryImpl.openConnectionImpl(ConnectionFactoryImpl.java:213)
org.postgresql.core.ConnectionFactory.openConnection(ConnectionFactory.java:51)
org.postgresql.jdbc.PgConnection.<init>(PgConnection.java:223)
org.postgresql.Driver.makeConnection(Driver.java:465)
org.postgresql.Driver.connect(Driver.java:264)
org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
javax.net.ssl.SSLException: Received fatal alert: protocol_version
sun.security.ssl.Alerts.getSSLException(Unknown Source)
sun.security.ssl.SSLSocketImpl.recvAlert(Unknown Source)
sun.security.ssl.SSLSocketImpl.readRecord(Unknown Source)
sun.security.ssl.SSLSocketImpl.performInitialHandshake(Unknown Source)
sun.security.ssl.SSLSocketImpl.startHandshake(Unknown Source)
org.postgresql.ssl.MakeSSL.convert(MakeSSL.java:41)
I have tested with no success:
Add ssl=false to the connection:
jdbc:postgresql://10.255.1.134:5432/pctc?ssl=false
Add sslmode=disable to the connection:
jdbc:postgresql://10.255.1.134:5432/pctc?sslmode=disable
and ignition.conf:
wrapper.java.additional.10=-Dhttps.protocols=TLSv1.2
https://jdbc.postgresql.org/documentation/head/connect.html#ssl
In PG Admin on the same machine, my conection is Ok with SSL mode disable
What version of Java 7? You may not have TLS 1.2 support without upgrading to Java 8.
We have java version 1.7.0_79.
In fact I don’t want especially to use SSL to connect to PostgreSQL v13,
but the JDBC connection parameters to disable SSL seems to have no effect…
Try this option as well: -Djdk.tls.client.protocols=TLSv1.2.
Unfortunately I don’t think TLS 1.2 is available in Java 7 until 1.7.0_95, which is an Oracle extended support version. Probably need to use Java 8 instead.
I don’t know anything about the Postegres JDBC driver or how to disable SSL/TLS all together.
It’s finally ok with:
Extra Connection Properties
sslmode=disable
