Ignition 7.6.7 OPC UA
I have an Igntion 7.6.7 with an opc ua module version 1.6.7 (b2014082615)
I´m trying to read my tags from a opc client application (OPC Expert V9.4.2305.31)
and i can connect but i don´t get the tags from scada.
I don´t know how can the system expose the tags.
I only see the diagnosis opc tags from the system and the devices tags created by adresses like you can see on the image attached.
May be the system doesn´t expose the tags and you must write the full item path or may be the system uses an id that i don´t know how can i relate it to the string tag path.
Thank you very much.
7.6 ? damn, you should get in touch with the Guinness book, you probably hold the record !
Note that not only is it OLD, it's also not a LTS release, if IA already used the even/odd number system back then.
Frankly with a version that old, only very few people will be able to help. I doubt even Phil remembers what exactly was going on in 7.6 !
Any chance you can update ?
Thank you [pascal.fragnofoud] but 7.6.7 version it´s the latest from 7.6
I'm into the same situation. I'll appreciate any kind of help
Please make a new post and include details like the version of Ignition you're using, what your problem is, what drivers you're using, what third party clients are involved, etc...
I support a system that's 7.5.x I think it's 7.5.3 but I forget. I've tried to get them to upgrade but to no avail.
but yes, 7.6 is pretty old.
That may be true but it's from roughly 2013. I think my core cert was in 7.8 in 2015.
It's very old and a version that is much harder to support.
