Hello All,
I’m interested in using custom scripting to add users to a roster. I’ve found the script I need to run in order to create new rosters, but I want to avoid using the “Roster Management” component to add/remove users from the roster. Are there scripting functions for doing this, or can it only be done via the Gateway/Roster Management component?
I did a little searching of the forums to see if this question had been asked, but all I was able to find was this post suggesting the upcoming addition of the script, and wasn’t sure if this had indeed been implemented in 7.8.
Thanks!
