Why would you not download 8.1.x?
If this is a licensed installation, they may have a 7.9 license but not a current support agreement.
To the original question can you verify the service is actually running?
Hi Josborn,
service is running, I have checked.
Hi Andrew,
The Project Backup i want to check is developed on 7.9
Share the install logs. Find it ~.\ignition\install\install.log
You should see this in the last lines
INFO [IgnitionInstaller ] [2021/07/26 22:15:36]: Starting Gateway. This should only take a moment..
INFO [IgnitionInstaller ] [2021/07/26 22:15:51]: Gateway service started and installed
INFO [IgnitionInstaller ] [2021/07/26 22:15:51]: Gateway started
INFO [IgnitionInstaller ] [2021/07/26 22:15:51]: Gateway Address: http://localhost:8088
Do you see a log level different than INFO?
