I need to connect to the ignition opc-ua server from different neworks ( three in this project).
Ignition Server is reachable in these three networks using three ethernet port.
The problem is that in the configuration of the server is possible write only one ip in the Endpoint Address field.
Trying to connect with any opc-ua client, the connection work only for the client in the same ip segment of the ip specified in Endpoint Address.
Is it possible to do this or not?
BR
Probably not in 7.9, unless you can somehow externally route 2 of the networks to the 1 network the server can bind to, in a manner that is transparent to the server.
The server configuration options are greatly improved in Ignition 8.x and this would definitely be possible if you can upgrade.
