Ignition 7.9.6 Installation Issue
I have installed Java 8 64-bit and am still getting a pop up, while attempting the Ignition install, that states that Setup was unable to locate Java 8.
Any direction on this?
Sometimes you have to restart the machine in order for the Environment variables needed for Java to take effect. Give that a try.
Tried that already. No luck there.
What OS and Java version do you have installed?
Running Windows 7 Enterprise. Had Java 8 Runtime Edition installed. Discovered that I actually needed Java 8 Development Edition. Once I installed that, Ignition installed with no issues. Thanks.
It would be good to know what is missing from the runtime that would matter to Ignition.
