I need help after update JAVA can’t open runtime
Are you using Ignition 7.9 or Ignition Maker edition (only in 8.0)?
Ignition 7.9.10
I moved this from Maker to Ignition category. Is this the Ignition gateway (7.9.10 launchers have Java 9 embedded)?
now after system restore windows10 many time can’t open ignition.
This looks like your system has Java configured to use a proxy, and that proxy requires authentication. Check with your IT group.
