Ignition 7.9 Swahili Language Support
(I first want to apologize if this has been asked before. If it has, I could not find it.)
Hello! I would like to inject a "new" language into the Ignition Translation Manager.
I believe this is possible because
import java.util.Locale as locale
x = locale('sw')
print x
locale.getDisplayLanguage(x)
returns
sw
u'Swahili'
Which tells me that the underlying java supports at least the idea of Swahili.
Are there other things behind the curtain that I can manipulate to get it added as an option in the Translation Manager?
(Yes, I know the Swahili language is supported in 8.x and that support for 7.9 is going away in December. Unfortunately, due to circumstances beyond my control, I cannot upgrade at this time.)
I have no idea what this would do, but you could try setting the java.locale.providers system property to include CLDR, to try to have Java include (all?) Unicode recognized locales:
https://docs.oracle.com/javase/8/docs/technotes/guides/intl/enhancements.8.html
You’d likely need to do that for your gateway and all client/designer launches, as well…
Thanks, Paul. Including java.locale.providers in the Gateway and Client launcher scripts has had no appreciable affect just yet. I’m looking to create a module to get it in the designer startup (per this thread: Designer Startup Script)
