When upgrading from 7.9 to 8.0.7, if the ‘Mouseover Text’ is a bad tag reference, it causes a ‘Bad_NotFound’ overlay when it did not use to. A current fix is to go through and either remove the tag binding or edit it to a valid path. This did not use to be an error in 7.9.
In this case, the tag is fine and reading correctly, but due to the Mouseover Text not being valid, it causes the whole thing to show as Bad_NotFound.
