Hello!
I have a problem using licensed Ignition 7.9 on a Windows Server 2019. The installation goes without problems adding the supplemental modules also(Serial support gateway and client), but after I add the first Modbus RTU device, the gateway crashes and in the log appears the following error
INFO | jvm 2 | 2024/06/05 15:27:23 | Serialio Library: version 10.2.3: build 9233
INFO | jvm 2 | 2024/06/05 15:27:23 | Copyright (c) 1996-2015 Serialio.com, All Rights Reserved.
INFO | jvm 2 | 2024/06/05 15:27:23 | os.name="Windows Server 2016" os.arch="amd64"
INFO | jvm 2 | 2024/06/05 15:27:23 | osName=Windows Server 2016 osArch=amd64
INFO | jvm 2 | 2024/06/05 15:27:23 | Platform not supported, check VM properties os.name & os.arch
Is there a workaround to solve this?
