Ignition 8.0.14
@paul-griffith
In Vision, when we disconnect the user and reconnect it, we have a lots of error, especially:
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/softPhone/status': Timer already cancelled.
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/blink': Timer already cancelled.
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/nbDesktop': Timer already cancelled.
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/softPhoneIsRegistered': Timer already cancelled.
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/tokenENE': Timer already cancelled.
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/tokenREJ': Timer already cancelled.
15:47:35.434 [ProjectDownloader] WARN Vision.ClientTag - Error creating tag binding for client tag '[client]_intern/tokenSIG': Timer already cancelled.
The vision client tag with these expression aren’t updated after the disconect/reconnect user
Here is the full client stack trace:
15:47:29.252 [AWT-EventQueue-0] INFO Common.BasicExecutionEngine - Execution engine 'ClientExecEngine' shut down in 0ms
15:47:29.252 [AWT-EventQueue-0] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Updated login state. Logged in? false, Username: null, Roles: null, Security Zones: null
gexcept null java.lang.IllegalStateException
at com.inductiveautomation.factorypmi.application.runtime.ClientContextImpl.getScriptManager(ClientContextImpl.java:543)
at com.inductiveautomation.factorypmi.application.VisionClientContextDelegateAdapter.getScriptManager(VisionClientContextDelegateAdapter.java:124)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:74)
at com.inductiveautomation.ignition.common.expressions.FunctionExpression.execute(FunctionExpression.java:69)
at com.inductiveautomation.factorypmi.application.sqltags.project.ExpressionTagBinding.childInteractionUpdated(ExpressionTagBinding.java:44)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.actionPerformed(AbstractPollingFunction.java:109)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction$1.run(AbstractPollingFunction.java:62)
at java.base/java.util.TimerThread.mainLoop(Unknown Source)
at java.base/java.util.TimerThread.run(Unknown Source)
15:47:31.997 [ForkJoinPool.commonPool-worker-27] WARN Common.BasicExecutionEngine - Execution rejected... running in calling thread [ForkJoinPool.commonPool-worker-27] immediately. [com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher@5bac4051]
15:47:31.997 [ForkJoinPool.commonPool-worker-27] ERROR Tags.Scripting.ScriptDispatcher - ([client]_intern/hightlightEqtPath, valueChanged) Error executing tag event script: null
java.lang.IllegalStateException: null
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$FunctionInvokerImpl.run(TagScriptManager.java:474)
at com.inductiveautomation.ignition.common.sqltags.scripts.AbstractTagScript.invoke(AbstractTagScript.java:33)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$Task.invoke(TagScriptManager.java:442)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.run(TagScriptManager.java:405)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine.executeOnce(BasicExecutionEngine.java:373)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine.executeOnce(BasicExecutionEngine.java:357)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.maybeSchedule(TagScriptManager.java:394)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.push(TagScriptManager.java:367)
at com.inductiveautomation.ignition.common.sqltags.scripts.TagScriptManager$TagScriptDispatcher.invoke(TagScriptManager.java:326)
at com.inductiveautomation.factorypmi.application.sqltags.AbstractClientTag.fireScriptEvent(AbstractClientTag.java:481)
at com.inductiveautomation.factorypmi.application.sqltags.AbstractClientTag.setCurrentValue(AbstractClientTag.java:229)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTag.setCurrentValue(ProjectTag.java:80)
at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTagManager.write(ProjectTagManager.java:535)
at com.inductiveautomation.ignition.client.sqltags.impl.SubManagerAdapter.lambda$writeAsync$1(SubManagerAdapter.java:166)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.exec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinTask.doExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool$WorkQueue.topLevelExec(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.scan(Unknown Source)
at java.base/java.util.concurrent.ForkJoinPool.runWorker(Unknown Source)
at java.base/java.util.concurrent.ForkJoinWorkerThread.run(Unknown Source)
15:47:34.387 [ClientPanel-LoginTask] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Skipping local challenge - directory doesn't exist.
15:47:34.387 [ClientPanel-LoginTask] INFO com.inductiveautomation.ignition.client.gateway_interface.GatewayConnectionManager - Updated login state. Logged in? true, Username: admin, Roles: [Administrator, BIL_cmd, BIL_param, ENE_cmd, ENE_param, GTC_ack_alarme, GTC_courbe, GTC_debug, GTC_param_role, GTC_visu, SAE_param, SIG_cmd, SIG_param, SIG_rejeu, SON_cmd, SON_param, STA_cmd, STA_param, SYS_cmd, SYS_param, TEL_cmd, TEL_param, VID_cmd, VID_param], Security Zones: null
Successfully read project CSTVG_GTC.proj from cache.
Cache file CSTVG_GTC.proj loaded sucessfully from cache, downloading diff...
15:47:34.856 [ProjectDownloader] INFO Vision.DownloadProjectPane - Starting download of 478 bytes
15:47:34.871 [ProjectDownloader] INFO tags.manager.gwinterface - Tag poll rate changed to 250 ms
15:47:34.871 [ClientExecEngine-1] INFO tags.subscriptions - Changing connected quality to 'Good'
15:47:35.340 [ProjectDownloader] ERROR Scripting.ScriptManager.STVG_GTC - Warning: collision at system.util.modifyTranslation
15:47:35.340 [ProjectDownloader] ERROR Scripting.ScriptManager.STVG_GTC - Warning: collision at system.util.translate
15:47:35.340 [ProjectDownloader] ERROR Scripting.ScriptManager.STVG_GTC - Warning: collision at system.util.initialize
15:47:35.465 [AWT-EventQueue-0] INFO vision.App - Starting Up...
15:47:35.934 [AWT-EventQueue-0] INFO Localization.ClientLocalizationManager - Setting current locale to 'fr'
15:47:36.481 [AWT-EventQueue-0] WARN Vision.Binding.ExpressionPropertyAdapter - Error executing expression binding on
BandeauHaut.Root Container.TemNotification.isPopupOpen
java.lang.Exception: Error executing expression binding on
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:92)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.startup(ExpressionPropertyAdapter.java:113)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupBindings(DefaultInteractionController.java:355)
at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupAdapters(DefaultInteractionController.java:360)
at com.inductiveautomation.factorypmi.application.FPMIWindow.startup(FPMIWindow.java:344)
at com.inductiveautomation.factorypmi.application.VisionDesktop$RuntimeWindowOpener.openWindow(VisionDesktop.java:549)
at com.inductiveautomation.factorypmi.application.VisionDesktop.openWindow(VisionDesktop.java:188)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.lambda$openWindowImpl$5(NavUtilities.java:393)
at com.inductiveautomation.factorypmi.application.script.builtin.WindowUtilities.doGUIAction(WindowUtilities.java:808)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindowImpl(NavUtilities.java:336)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilities.openWindow(NavUtilities.java:326)
at com.inductiveautomation.factorypmi.application.script.builtin.NavUtilitiesDispatcher.openWindow(NavUtilitiesDispatcher.java:143)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:524)
at org.python.core.PyObject.__call__(PyObject.java:480)
at org.python.core.PyObject.__call__(PyObject.java:484)
at org.python.pycode._pyx144.initPrimaryMonitor$4(<module:project.nav.windows>:132)
at org.python.pycode._pyx144.call_function(<module:project.nav.windows>)
at org.python.core.PyTableCode.call(PyTableCode.java:171)
at org.python.core.PyBaseCode.call(PyBaseCode.java:125)
at org.python.core.PyFunction.__call__(PyFunction.java:403)
at org.python.pycode._pyx152.run$1(<module:project.clientevents.startup>:115)
at org.python.pycode._pyx152.call_function(<module:project.clientevents.startup>)
at org.python.pycode._pyx146.f$0(<startup script>:3)
at org.python.pycode._pyx146.call_function(<startup script>)
at org.python.core.Py.runCode(Py.java:1614)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:782)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:753)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:715)
at com.inductiveautomation.factorypmi.application.FPMIApp.startup(FPMIApp.java:490)
at com.inductiveautomation.factorypmi.application.runtime.ClientPanel.lambda$startupApp$7(ClientPanel.java:698)
Caused by: java.lang.IllegalStateException: Timer already cancelled.
at java.base/java.util.Timer.sched(Unknown Source)
at java.base/java.util.Timer.schedule(Unknown Source)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.startTask(AbstractPollingFunction.java:65)
at com.inductiveautomation.ignition.common.expressions.functions.AbstractPollingFunction.setPollRate(AbstractPollingFunction.java:95)
at com.inductiveautomation.ignition.common.expressions.functions.ScriptFunction.execute(ScriptFunction.java:72)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:83)
... 52 common frames omitted
BandeauHaut.Root Container.TemVideo.isPopupVisible
15:47:36.496 [AWT-EventQueue-0] WARN Vision.Binding.ExpressionPropertyAdapter - Error executing expression binding on
BandeauHaut.Root Container.isBuzzerPlaying
15:47:36.903 [AWT-EventQueue-0] WARN Vision.Binding.ExpressionPropertyAdapter - Error executing expression binding on
BandeauGauche.Root Container.nbScreen
