Ignition 8.0.2-rc1 - Unexpected error executing expression/db tag
During the creation of udt tags instance, I have the following error in the gateway
tags.execution.actors.expr
expr	29May2019 15:15:22	Unexpected error executing expression/db tag.
java.lang.NullPointerException: null
at com.inductiveautomation.ignition.gateway.tags.runtime.nodes.ExecutableTag.valueChanged(ExecutableTag.java:278)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractValueGeneratingActor.fireValueChange(AbstractValueGeneratingActor.java:41)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractValueGeneratingActor.fireValueChange(AbstractValueGeneratingActor.java:34)
at com.inductiveautomation.ignition.gateway.tags.actors.factories.value.AbstractExpressionActor.run(AbstractExpressionActor.java:131)
Hi mazeyrat,
Could you provide me with a gateway backup of the issue for easy reproduction?
Thanks,
Anthony
Sorry I can’t send you a backup before next week.
No problem send it whenever you are able to
