Ignition 8.1.17 21CFR E signature
in ignition 8.1.17, e-signature is possible in perspective object, but can we implement the e-signature in the vision screen window ? if yes then how ?
There’s no special handling for elevation, nor a directly implemented signature component in Vision.
However, you generally have much lower level access via scripting, so you could probably still make something workable.
I haven’t touched it in a long time, but I made a template that wraps around the Paintable Canvas component that would allow you to capture a signature ~easily:
