Trying to setup Ignition to access a database on the local host. Keep getting error messages for unauthenticated cache.sha2.password or poolable connection factory.. class java.math.Biginteger.
the user manual seems to skip a few steps.
Let's start with a copy/paste of the full error stack trace text.
This is one of them
java.sql.SQLException: Cannot create PoolableConnectionFactory (Unable to load authentication plugin 'caching_sha2_password'.)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:656)
at org.apache.commons.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:534)
at org.apache.commons.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:734)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.getConnectionInternal(DatasourceImpl.java:300)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceImpl.runTest(DatasourceImpl.java:253)
at com.inductiveautomation.ignition.gateway.datasource.DatasourceManagerImpl$FaultedDatasourceRetryer.lambda$newRetryRunnable$0(DatasourceManagerImpl.java:1096)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:587)
at java.base/java.util.concurrent.FutureTask.runAndReset(Unknown Source)
Caused by: java.sql.SQLException: Unable to load authentication plugin 'caching_sha2_password'.
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:926)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:923)
at com.mysql.jdbc.MysqlIO.proceedHandshakeWithPluggableAuthentication(MysqlIO.java:1725)
at com.mysql.jdbc.MysqlIO.doHandshake(MysqlIO.java:1250)
at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2465)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2498)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2283)
at com.mysql.jdbc.ConnectionImpl.(ConnectionImpl.java:822)
at com.mysql.jdbc.JDBC4Connection.(JDBC4Connection.java:47)
at jdk.internal.reflect.GeneratedConstructorAccessor111.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:404)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:317)
at org.apache.commons.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:52)
at org.apache.commons.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:357)
at org.apache.commons.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:103)
at org.apache.commons.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:652)
... 12 more
and this is the other one
java.sql.SQLException: Cannot create PoolableConnectionFactory (java.lang.ClassCastException: class java.math.BigInteger cannot be cast to class java.lang.Long (java.math.BigInteger and java.lang.Long are in module java.base of loader 'bootstrap'))
Caused by: java.sql.SQLException: java.lang.ClassCastException: class java.math.BigInteger cannot be cast to class java.lang.Long (java.math.BigInteger and java.lang.Long are in module java.base of loader 'bootstrap')
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1074)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:988)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:974)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:919)
at com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1062)
at com.mysql.jdbc.ConnectionImpl.initializePropsFromServer(ConnectionImpl.java:3556)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2513)
... 12 more
Caused by: java.lang.ClassCastException: class java.math.BigInteger cannot be cast to class java.lang.Long (java.math.BigInteger and java.lang.Long are in module java.base of loader 'bootstrap')
at com.mysql.jdbc.ConnectionImpl.buildCollationMapping(ConnectionImpl.java:1007)
... 27 more
I think you may need to upgrade the MySQL JDBC driver.
i will give a try, thanks
Already had the latest and greatest
Hmm, not sure. Screams JDBC / MySQL version mismatch to me.
QA is going to spin something up with the latest MySQL JDBC and server to sanity check.
No issue with 8.0.33... might want to call support and let them take a look.
thanks
Is there any update on this? I have the exact same issue, same error.
There is a Knowledgebase article here walking you through how to get your MySQL 8 database connected in Ignition. In addition to updating to the latest JDBC driver, there are Extra Connection Properties that need to be changed.
Thanks so much. I had all the correctly installed components but I had not yet made any modifications to JDBC driver or existing Database I had already setup in Ignition. That seems to have fixed me right up, thanks!
