Am installed Ignition Version: 8.1.30 (b2023071408) & Production 3.81.9 (b2023062424), OEE Downtime 3.81.9 (b2023062424). In designer Production module is not showing. How to retrieve the module.
Check if it's listed in View | Panels and enable it, if required. (I can't think of any other reason you can't see it.)
Look for errors in the designer's local log viewer, in case the Sepasoft module failed to load in the designer.
