I have the beta version installed on two different VM’s hosted in Azure. The Gateways are working OK but when I try to launch a designer the Window seems to open but you can never get focus. The screen shot shows two windows open. I cannot switch to them by clicking on the window or ALT Tab. Is this a known bug? I have Maker 8.3 installed on a Linux server and I haven’t seen this, so it’s either something to do with the Azure environment, the full version, or a combination.
First, you list v8.1.36 beta in your title, but v8.3 is the beta version, so I’m guessing you’re off on it.
If you’re trying to use a v8.1 launcher with v8.3, I’m not sure if it will work, so I would make sure you’re using the latest launcher installed from the gateway web page to ensure you have a proper and compatible version. I know the launcher for v8.3 can launch v8.1 projects, but not sure if it will work the other way around.
