Hi all
Is it possible for a project to inherit from another project that is not on the same gateway but is connected via gateway network?
The idea is to develop everything on the dev server machine and have the other machine running projects that inherit from the project on the dev machine. If it’s not possible I think I can use a solution where each gateway has a copy of the development project and all projects on that gateway inherit from it. The EAM module can help for the propagation of the development project to all gateways in the network
Regards
Each gateway will need a copy of the project.
Ok. Thanks
