Ignition 8.1 Perspective – Agitator rotation direction in Vessel symbol
Hi everyone,
I’m using Ignition 8.1 Perspective and working with the Vessel symbol that includes an agitator.
I’m able to:
  • Animate the agitator rotation
  • Control the rotation speed dynamically using tag bindings
The only issue I’m facing is that I cannot change the rotation direction (clockwise vs counter-clockwise). The agitator always rotates in the same direction, and I don’t see any exposed property or setting to control direction.
My questions:
  • Is the rotation direction fixed for the built-in Vessel agitator?
  • Is there any supported way in Perspective to control or reverse the rotation direction using bindings, transforms, or styles?
Any clarification or guidance would be appreciated.
Thanks!
Are you having a laugh? The animation on the vessel is a shrink and expand of the agitator elements in the horizontal direction. There is no direction to this animation, its a visual illusion that it "rotates" at all.
Brilliant!
When you have a genuinely directional animation you can use CSS transform. For example: Perspective Centrifugal Pump Animation Help - #2 by Transistor.
