Ignition 8.1 Perspective Table - Column Filter Not Dropping Down Filter Options
I have a table that has name and roles columns. Only the 'LastName' column's filter seems to be broken.
Below: the 'Roles' column filter working as expected
Below: the 'LastName' column filter not opening dropdown
The filter property for all columns has enabled set to true and this is only being seen in the test environment. The development environment filter works as expected.
I haven't been able to find any reference of this problem elsewhere so hopefully this might attract some ideas.
Would like to also chime in on this topic: it happens often for tables which were created before the introduction of the "column filter" feature in ignition because some JSON metadata is not correctly inserted in the table.
Sometimes deleting the columns element and recreating the columns from scratch fixes the problem because the JSON for the columns and especially the filter object is recreated correctly.
In some other instances not even recreating all the columns fixes it.
Since no one responded, I’ll answer my own question. If there are empty cells in a column or if Ignition has trouble determining the column type, the frontend JavaScript can fail, preventing the filter dropdown from appearing. A workaround is to explicitly set the column type to 'string' instead of relying on 'auto'.
