Ignition 8.3.0 - System Functions - Code completion discrepancies - Docs vs Designer/Console Script
Hello IA,
I would like to report some discrepancies between the Docs and the Designer/Console Script.
Note: This might not be an exhaustive list, but it is what I was able to find.
Function Docs Designer
system.db.runQuery Missing.
system.db.runScalarPrepQuery Missing.
system.db.runScalarQuery Missing.
system.db.SFNamedQuery Present in docs. Deprecated.
system.db.SFPrepUpdate Missing.
system.db.SFUpdateQuery Present in docs. Deprecated.
system.db.runUpdateQuery Missing.
system.historian.queryAggregatedPoints Missing.
system.historian.queryRawPoints Missing.
system.historian.queryValues Present in docs. Not listed.
system.net.httpDelete Present in docs. Deprecated.
system.net.httpGet Present in docs. Deprecated.
system.net.httpPost Present in docs. Deprecated.
system.net.httpPut Present in docs. Deprecated.
system.roster.getUsers Missing
syste,security.getUserRoles Present in docs. Deprecated.
syste,security.validateUser Present in docs. Deprecated.
system.tag.browseHistoricalTags Present in docs. Deprecated.
system.tag.deleteAnnotations Present in docs. Deprecated.
system.tag.queryAnnotations Present in docs. Deprecated.
system.tag.queryTagCalculations Present in docs. Deprecated.
system.tag.queryTagDensity Present in docs. Deprecated.
system.tag.queryTagHistory Present in docs. Deprecated.
system.tag.storeAnnotations Present in docs. Deprecated.
system.tag.storeTagHistory Present in docs. Deprecated.
system.util.getAvailableLocales Present in docs. Deprecated.
system.util.getAvailableTerms Present in docs. Not listed.
system.vision.getAvailableLocales Missing.
system.vision.getAvailableTerms Missing.
system.vision.invokeLater Present in docs. Deprecated.
system.vision.validateUser Missing.
There are also differences between the Script Console code completion and the code completion for scripts on the Designer.
I would like to know what's the source of truth? The Designer or the docs?
Thanks!
EDIT: This was created using version 8.3.0-beta3 (b2025081112).
Thanks for bringing these to our attention! There are a number of changes to many of the system functions listed here in the Upgrade Guide:
Some of the functions listed as missing are actually present in the Deprecated pages section of the user manual, while others that are listed as present in the docs have a note near the top of the page calling them out as deprecated. I went through and added links where I could to clarify, and we'll take another pass through to ensure we're handling deprecated functions the same way across the board. The 8.3 docs are still a work in progress, so we're still making some revisions where needed in order to make sure the docs reflect what's present in the software.
Function Docs Designer Notes
system.db.runQuery Missing. system.db.runQuery | Ignition User Manual
system.db.runScalarPrepQuery Missing. system.db.runScalarPrepQuery | Ignition User Manual
system.db.runScalarQuery Missing. system.db.runScalarQuery | Ignition User Manual
system.db.SFPrepUpdate Missing. system.db.runSFPrepUpdate | Ignition User Manual
system.db.SFUpdateQuery Present in docs. Deprecated. Deprecated in Vision only
system.net.httpDelete Present in docs. Deprecated. Note on page: This function was deprecated in 8.3, use system.net.httpClient.delete.
system.net.httpGet Present in docs. Deprecated. Note on page: This function was deprecated in 8.3, use system.net.httpClient.get.
system.net.httpPost Present in docs. Deprecated. Note on page: This function was deprecated in 8.3, use system.net.httpClient.post.
system.net.httpPut Present in docs. Deprecated. Note on page: This function was deprecated in 8.3, use system.net.httpClient.put.
system.vision.invokeLater Present in docs. Deprecated. Note on page: This function replaces system.util.invokeLater. Any scripts containing Vision Client scoped functions that were replaced with system.vision syntax will still work to maintain backwards compatibility. Only the system.vision variations will appear in the Script Editor's autocomplete popup.
As far as the difference in behavior you're seeing between the Script Console and the Designer, that may be related to the scope of the script you're writing. If the function you want is not part of the selected scope, it won't show up in the autocomplete hints.
We'll get things sorted out in the docs to verify what the correct behavior should be and make sure the appendix is updated to match. Please let us know if you spot anything else that needs our attention.
Taking into account that the following functions are deprecated as per the docs, should we consider the following suggestions as bugs within the Designer?
system.db.runQuery
All of them are not identified as deprecated.
Current behavior[1]:
Expected behavior:
:warning: system.db.runQuery
:warning: system.db.runScalarPrepQuery
:warning: system.db.runScalarQuery
:warning: system.db.SFPrepUpdate
  1. Using 8.3.0-beta4 (b2025081810). ↩︎
And regarding system.vision.invokeLater, this is currently showing as deprecated in the Designer.
If I understand correctly, system.util.invokeLater is deprecated but not system.vision.invokeLater
These are the deprecated fields and functions for system.vision:
Which is kind of odd, considering this is a brand new module.
system.vision.invokeLater indeed should not be deprecated in the software - that's an issue on our end (likely to survive into 8.3.0 with current timing, but should be fixed by 8.3.1).
The system.db functions indeed should be deprecated - looks like a merge conflict got goofed somewhere along the way. Similar story, but the inverse - these should be deprecated in the software, but that discrepancy may not get fixed for 8.3.0.
  • system.security.getUserRoles
  • system.security.validateUser
These two functions actually should not have been deprecated and moved to system.vision - they work across all scopes, unlike the other functions in system.security that actually only work within Vision's scope. As a result, these two have been un-deprecated and the system.vision alternatives removed, in either RC2 or 8.3.0 final.
From 8.1 to 8.3 Upgrade Guide | Ignition User Manual :
The pager.initialOption property for Perspective Tables has been deprecated and replaced with a new option property. This new property improves on the deprecated property by honoring external writes even after the table initializes upon loading.
That should say activeOption, not option.
