Ignition 8.3.10 Is Available For Download!
Ignition 8.3.10 Is Available for Download!
Please Note: From now on we’ll be publishing details on the latest minor versions of Ignition here on the Ignition Forum in Release Announcements, instead of on the Inductive Automation blog. We will only be publishing release blog posts on the Inductive Automation blog for major releases of Ignition. Subscribe to Release Announcements to be among the first to know about new minor releases.
Ignition 8.3.10 has just been released, and you can download it here. 8.3.10 includes several small optimizations and bug fixes, including:
The following default Extra Connection Properties have been added to PostgreSQL database connections:
  • autosave=always
  • cleanupSavepoints=true
This enables PostgreSQL connections to better handle PK (Primary Key) errors.
For Alarm Status and Alarm Journal Table components, the pager.initialOption property has been replaced with a pager.activeOption property.
This will give components more control over the count of rows that will appear per table page. With this change, the Alarm Journal and Alarm Status tables have the same property as the Perspective Table component.
In 8.3.10, loading an archived cache will create a dedicated database connection and data sinks to forward through.
This fix helps ensure the practice of backfill connections is still possible for Ignition 8.3 and future Ignition versions that useSQL historians.
An optional extendedProperties parameter has been added to the system.historian.queryAggregatedPoints() function. This fixes an issue where, previously, querying points using the Count aggregation mode from the SQL Historian resulted in inflated aggregate counts.
As a result you now have better control of your raw data point counts when using the Count aggregation mode.
You can now send error reporting to multiple people at once. The “To Address” field under Platform > Gateway Settings > Error Reporting will now accept a semicolon-delimited list of email addresses:
And lastly, you can now adjust HTTP client and thread pool settings on the Gateway Network’s General Settings page with the addition of the following:
Data Channel Thread Pool Initial Size setting:
HTTP Client Max Allow Connections setting:
Previously, these settings could only be changed through additional wrapper properties. But now you can rely on HTTP Client Max Allow Connections to properly match a connection pool size to any configured thread pool count.
:down_arrow: Download Ignition 8.3.10 now — get it here.
Ignition 8.3.11 is scheduled to be released in mid-November.
Great that you are publishing the details on minor releases on the forum. It will make it more accessible and easy to find later.
It would be nice if the details was split up into sections with a header. Reading through this it just jumps from one thing to another and gets a bit harder to spot something later on if you go back to the post.
There are complete changelogs posted on this forum in the Early Access category. You should set your forum account to "Watch" those topics, perhaps that whole category. Anything more than a summary in this category would be redundant.
Plus there are release notes on the downloads page that give you a single stop for all of it.
For sure one should check the complete changelogs and release notes for detailed info on the changes.
This was merely just as feedback for making these summaries more readable.
Glad to see this, but when I just tested this, those extra connection properties were not there, and I didn't see anything in the changelogs for this. Are these added behind the scenes? I've gone ahead and added the following line on all my current connections to see if it fixes the periodic PK errors we get on our historian w/TimescaleDB.
autosave=always;cleanupSavepoints=true;
I've also used this extra connection property in the past with other DBs but not sure if it's necessary or helps on PostgreSQL performance?
reWriteBatchedInserts=true;
Extra connection props won't really ever show up on existing systems.
The default values in the "driver" behind each connection are seeded on startup and then persisted in configuration files. We, as a general rule, don't like to rewrite configuration that's potentially valid/working, so we don't touch these files just because you upgraded. So you'd only see the new default values in a brand new gateway installation when we seed the values.
And then, even if you change the default values in the driver yourself, it also won't take effect on any existing database connections - only newly created ones.
So this did not resolve any of my primary key errors I was getting. I left off the rewriteBatchedInserts as I believe it would make matters worse. AI is suggesting some changes/triggers to add to the database to silently ignore these errors, so I may test that in an offline setup first to see if it makes a difference.
