Ignition 8.3.9 – Perspective Missing in Designer
Hi team,
Today I installed the new version of Ignition 8.3.9 (b2026082511) along with the Designer.
However, I noticed that Perspective is missing from the Designer. Both the Vision and Perspective modules are installed and showing as ACTIVE in the Gateway.
I also understood that Ignition 8.3 includes the new built-in vector-based image functionality, but I could not find this feature in the Designer either.
Did I miss something during the installation, or is Perspective not available/supported in this version?
I would appreciate any advice.
Thank you!
I think module perspetive is not installed, check modules in platform/Modules
Are there any errors in the designer console? From memory if there is a failure of jxbrowser the module doesn’t load in the designer at all.
The perspective module is installed and active.
As @David_Stone says, if the JxBrowser engine faults on designer startup, Perspective will be missing. Look at the designer's console for likely messages about that.
14:15:16.699 [Designer-Startup] ERROR designer.JXBrowserUtil -- Failed to start Browser Engine with options
com.teamdev.jxbrowser.engine.EngineOptions:
autoplayEnabled: false
chromiumDir: C:\Users\Saip.ignition\cache\resources\jxbrowser\8.16.0
chromiumSwitches:
diskCacheSize:
fileAccessFromFilesAllowed: false
isGpuDisabled: false
isIncognitoEnabled:true
language:en-us
passwordStore:
remoteDebugginPort: 9222
renderingMode: OFF_SCREEN
isSandboxDisabled: false
secureOriginWhitelist:
isTouchMenuEnabled: false
userAgent:
userDataDir:C:\Users\Saip\AppData\Local\Temp\JxBrowser-UserData-99ebefde-7f6c-4932-82de-92b864663814
webSecurityDisabled: false
Huh. That's the problem, but I was expecting more information. Can you disable AV or other malware software temporarily?
I fixed the issue by renaming the old cache folder and then restarting everything.
Thanks to all of you for your help!
