I have defined a database connection to an SQL Server named IgnitionDB, which is valid
If I run
I get the following error:
whereas named queries are running ok.
I'm on Ignition
Any idea?
Thanks in advance, regards
If I run
I'm on Ignition
Any idea?
Your DB name as defined in the Gateway has a bunch of typos in it compared to what you've got in your script.
Your are right @Kevin.Herron ... sorry, it's evening here ![]()
