Hi Experts,
I’m using Ignition 8.3 with the following setup:
Edge Gateway collecting PLC data
Central Gateway with PostgreSQL as the historian (
Postgres_Historian) -
Gateways are connected through a trusted Gateway Network
The Edge tags are visible in the Central Gateway Designer, but when I enable history for them, I can’t select the Postgres_Historian storage provider.
Tags created locally in the Central Gateway historize fine, but Edge tags do not store history.
This setup worked perfectly in Ignition 8.1, so I believe I may be missing some configuration in 8.3.
Any guidance on what changed or needs to be adjusted in 8.3 to historize Edge tags would be appreciated.
