Ignition 8.3 GIT Deployment Best Practices
Are there any articles available to support setting up GIT version control for Ignition 8.3 projects?
Similar to Ignition 8 Deployment Best Practices | Inductive Automation
Which folders would need to be tracked to capture tags, images and gateway configurations into a GIT repository?
It would be awesome if it was possible to automatically migrate binary files from projects pulled from GIT repositories, rather than having to do a gateway restore.
You'll probably have to wait a while for complete guides to become available.
For now, I'll mention that files created in the external "resource collection" (also known as mode or just collection; roughly analogous to a "project") are guaranteed to go untouched by Ignition and will be treated as immutable. If you want to preconfigure/deploy gateways from source control, that's going to be your preferred avenue - essentially, duplicate the nested folder structure from
data/config/resources/core/
and manually repeat it in
data/config/resources/external/
for whatever resources you care about.
'Gateway configurations' is too broad - basically everything in the gateway is now captured in independent resource types, so you have to choose how selective (or not) you want to be when storing configuration to VCS. Images, for instance, are stored in data/config/resources/core/ignition/images.
Any plans for / any existing documentation of the new file structure?
Almost certainly, yes, but I'm not on the documentation team so I can't say authoritatively.
A quick look at the manual found:
The resource.json manifest file works the same for gateway/configuration resource as it does for projects:
Thanks for the quick answer! Definitely nice to see all the resources in JSON format :smile:
If we were happy tracking all the changes the gateway makes in a basic dev/production server environment, would it be safe to push/pull directly to/from the 'core' folder, or would this risk corrupting the gateway in some instances?
The gateway doesn't scan for changes to the resources on disk in 8.3, so you'll have to update your deployment automation/process to (for now) hit the scan config collection endpoint on our new REST API. Other than that, the only 'risk' is having written out files/folders that don't make sense to the gateway and cause issues.
Are these endpoints publicly documented anywhere yet? Currently mid-rebuild on Flint for 8.3, and looking to add support for the native project scan endpoint.
I suspect right now the only documentation is at http://localhost:8088/openapi or http://localhost:8088/openapi.json.
e.g. the scan endpoint is documented at http://localhost:8088/openapi#tag/config-management/paths/\\\\\\\~1data\\\\\\\~1api\\\\\\\~1v1\\\\\\\~1scan\\\\\\\~1projects/post
At some point there should be a scripting interface to some/all of the REST API as well. @paul-griffith can speak to that more than I can.
Yeah, the plan is still a "complementary" scripting API - it won't be a 1:1 copy of the REST API but will be able to express ~all the same capabilities. Timeline is no earlier than 8.3.1.
