Ignition 8.3 Module Sub Namespace & Autocomplete
I have created a module and installed it in Ignition 8.3. Everything is working fine except everything in my parent namespace appears in autocomplete in designer but everything in a sub namespace does not. The code works and executes fine in both cases. For example:
Script module path = "system.abc”
  • system.abc.divide() appears in autocomplete and executes without errors
  • system.abc.def appears in autocomplete
  • system.abc.def.divide() does not appear in autocomplete but does execute without errors
Should autocomplete be able to detect and show system.abc.def.divide()? Is there a working example or doc I can follow or perhaps I’m missing something really simple?
Thanks!
Not sure, but I've never seen any autocomplete at the 4th level.
Late, but this definitely works; see system.perspective.workstation functions:
These are mounted by Perspective in pretty much the way you'd expect, so I'm not sure what might be going wrong in your case.
  @Override
  public void initializeScriptManager(ScriptManager manager) {
    PropertiesFileDocProvider docProvider = new PropertiesFileDocProvider();
    manager.addScriptModule("system.perspective", scriptFunctions, docProvider);
    manager.addScriptModule("system.perspective.workstation", workstationScriptingFunctions, docProvider);
Both Embr-Thermo and Embr-SNMP have 4th level autocomplete with no issues.
