ekb
1
Hey all
I’m running into a problem after upgrading from Ignition 8.1 to 8.3.1 involving OIDC (Keycloak) authentication through NGINX as a reverse proxy.
Setup:
The flow worked fine in 8.1:
- Browser redirects from Ignition → Keycloak
- Keycloak handles login and redirects back to Ignition’s
/data/federate/callback/oidc
- Designer launched successfully
Now in 8.3.1:
- I had to change in my nginx config:
- Keycloak redirects correctly, the browser receives a
302 after login
- I'm encountering a
502 Bad Gateway when trying to access /data/config/web-server
- But the Ignition Designer client (Jetty) follows the redirect and gets a
444 response from NGINX
- This seems to break the login session
From the logs:
GET /data/federate/callback/oidc?... HTTP/1.1" 302 ...
GET /data/federate/callback/oidc?... HTTP/1.1" 444 ...
User-Agent: Jetty/12.0.15
What I’ve tried:
- I added a specific NGINX
location = /data/federate/callback/oidc block, allowing access to that path
- I also tried relaxing method blocking rules for that exact URI
- Regular browser login works, but Designer fails after redirect
My nginx site config:
server {
server_name scada.example.com;
if ($request_method !~ ^(GET|POST|HEAD|PUT|DELETE|PATCH|OPTIONS)$ ) {
return 444;
# Nginx Bad Bot Blocker Includes
# REPO: https://github.com/mitchellkrogza/nginx-ultimate-bad-bot-blocker
include /etc/nginx/bots.d/ddos.conf;
include /etc/nginx/bots.d/blockbots.conf;
add_header Strict-Transport-Security "max-age=63072000; includeSubDomains; preload" always;
add_header X-Content-Type-Options nosniff;
add_header X-Frame-Options DENY;
add_header X-XSS-Protection "1; mode=block";
add_header Referrer-Policy "no-referrer" always;
location / {
proxy_connect_timeout 600s;
proxy_send_timeout 600s;
proxy_read_timeout 600s;
send_timeout 600s;
client_max_body_size 100M;
proxy_http_version 1.1;
proxy_cache_bypass $http_upgrade;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Port 443; # The proxy is listening on port 443
proxy_set_header X-Forwarded-Host $host;
proxy_pass https://10.0.0.10:8043; #Use ignition container ip address
proxy_hide_header Strict-Transport-Security;
proxy_hide_header X-Content-Type-Options;
proxy_hide_header X-XSS-Protection;
proxy_hide_header X-Frame-Options;
proxy_hide_header Referrer-Policy;
location = /data/federate/callback/oidc {
location /system/images/ {
proxy_set_header X-Forwarded-Port $server_port;
proxy_pass http://10.0.0.10:8088; #Use ignition container ip address
location /data/perspective/ {
location /res/perspective/ {
location /system/perspective-download/ {
location /system/pws/ {
location /system/gwinfo {
listen 443 ssl; # managed by Certbot
# SSL-certifikat
ssl_certificate /etc/letsencrypt/live/scada.example.com-0001/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/scada.example.com-0001/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
listen 80;
listen [::]:80;
return 301 https://$host$request_uri;
#if ($request_method !~ ^(GET|POST|HEAD)$ ) {
return 444;
Has anything changed in how Ignition 8.3.1 handles OIDC / Designer auth flow via Jetty?
Any tips on how to structure NGINX for this version? I’d appreciate any help
ekb
2
I got it to work with firefox, designer, nginx and keycloak with this config:
# SCADA Reverse Proxy for Ignition 8.3 + OIDC
# https://scada.example.com
server {
listen 443 ssl;
# SSL Config (Let's Encrypt)
# Allow headers with underscores (required for Perspective)
underscores_in_headers on;
# Timeouts & upload limits
send_timeout 600s;
# Security headers
# ^|^e Whitelist Jetty user-agent (Ignition Designer)
if ($http_user_agent ~* "Jetty") {
set $bad_bot 0;
set $validate_client 0;
set $bad_words 0;
set $bad_referer 0;
# Optional: DDoS/bot protection
# 🔐 Keycloak OIDC callback
proxy_ssl_verify off;
# proxy_http_version 1.1;
proxy_pass_request_headers on;
# 🔁 General proxy settings
location ^~ /data/ {
proxy_pass https://10.0.0.10:8043/data/;
proxy_set_header Connection "upgrade";
location ^~ /system/ {
proxy_pass https://10.0.0.10:8043/system/;
location ^~ /res/ {
proxy_pass https://10.0.0.10:8043/res/;
location ^~ /idp/ {
proxy_pass https://10.0.0.10:8043/idp/;
location ^~ /.well-known/ {
proxy_pass https://10.0.0.10:8043/.well-known/;
# 🎯 Default fallback
location / {
proxy_pass https://10.0.0.10:8043/;
# Redirect all HTTP traffic to HTTPS
server {
listen 80;
listen [::]:80;
# # Optional: block invalid HTTP methods
return 444;
