Hi all, I am using Ignition 8.3 with the Siemens Enhanced driver with S7 symbolic communication to an S7-1500 and came across some unexpected behavior with the OPC item paths that I wanted to clarify.
I am copying over some old UDTs + tags from an 8.1 project where the same S7-1500 PLC was hosting an OPC-UA server for testing. When I add a new tag from the Ignition OPC-UA server directly from the tag browser, the tag path does not contain any quotation marks and seems to work totally fine.
The weird part to me was that I have some tags that still have quotation marks in the OPC item path from OPC syntax but they still work.
The Siemens Enhanced Driver documentation does not indicate anything about quotes, so I’m curious when/if they can/should be used.
Thank you!
