Ignition 8 Edge - Error Sending Email
We have an installation of Ignition Edge Version: 8.0.3 (b2019080717) and have some tags configured with alarm, As per my understanding Ingition Egde comes with a default Alarm email notification.
We have configured the SMTP profile using AWS SES correctly, however everytime an alarm is activated we get the following error message in the logs -
OneWayNotificationProfile	06Dec2019 02:06:32	Error sending notification email:
com.sun.mail.smtp.SMTPSendFailedException: 501 Invalid MAIL FROM address provided
at com.sun.mail.smtp.SMTPTransport.issueSendCommand(SMTPTransport.java:2202)
at com.sun.mail.smtp.SMTPTransport.mailFrom(SMTPTransport.java:1693)
at com.sun.mail.smtp.SMTPTransport.sendMessage(SMTPTransport.java:1194)
at javax.mail.Transport.send0(Transport.java:254)
at javax.mail.Transport.send(Transport.java:124)
at com.inductiveautomation.ignition.alarming.notification.email.OneWayNotificationProfile$EmailTask.run(OneWayNotificationProfile.java:264)
at com.inductiveautomation.ignition.alarming.notification.email.OneWayNotificationProfile.lambda$new$0(OneWayNotificationProfile.java:73)
at com.inductiveautomation.ignition.common.util.ThrottlingAggregator.check(ThrottlingAggregator.java:94)
at com.inductiveautomation.ignition.common.util.ThrottlingAggregator$1.run(ThrottlingAggregator.java:113)
Caused by: com.sun.mail.smtp.SMTPSenderFailedException: 501 Invalid MAIL FROM address provided
at com.sun.mail.smtp.SMTPTransport.mailFrom(SMTPTransport.java:1700)
Does anybody have encountered an issue like this?
Thanks.
I would suggest not, as code 501 is coming from AWS. Specifically, you must specify the "from" address that is authorized to send email via your AWS account.
