Ignition 8 Find and replace not working
The find and replace function is not working correctly. It does replace all of the items found no matter how many time you press replace all or just replace.
Which items, in which area? Find and replace has to be individually implemented for each module, so knowing what you’re trying to replace would help a lot.
The only way I was able to replicate this is if I manually selected each matching result so that the Replace portion of the window declared “X items selected”, at which point ONLY “Replace” is enabled, and the single press would indeed then replace all selected instances of the occurrence with the supplied replacement text.
Would you be able to supply a View you encountered this behavior in and what you were looking to replace? What version are you using currently?
I am using 8.0.2 the items trying to replace are within an OPC tag assigned in a UDT
