Ignition 8 - list expression functions and categories (for the gateway scope)?
I try to list the expression functions and categories (for the gateway scope)
it seems possible:
http://files.inductiveautomation.com/sdk/javadoc/ignition80/8.0.14/com/inductiveautomation/ignition/common/expressions/FunctionFactory.html
from com.inductiveautomation.ignition.common.expressions import BasicFunctionFactory
print BasicFunctionFactory().getFunctionNames()
return in the designer console
perhpas public BasicFunctionFactory​(FunctionFactory parent) ??? but where to find parents…
BasicFunctionFactory is just a basic/default implementation. Creating a new one will of course be empty.
DefaultFunctionFactory has all the built-in expression functions.
from com.inductiveautomation.ignition.common.expressions import DefaultFunctionFactory
print DefaultFunctionFactory().getFunctionNames()
print DefaultFunctionFactory().getCategories()
print DefaultFunctionFactory().getFunctionsInCategory()
return:
  File "<input>", line 14, in <module>
TypeError: No visible constructors for class (com.inductiveautomation.ignition.common.expressions.DefaultFunctionFactory)
Hmm, it’s deprecated, but try DefaultFunctionFactory.getSharedInstance().
You can also get the FunctionFactory from a GatewayContext (or anything that extends CommonContext, really).
thanks a lot :+1:
categories = DefaultFunctionFactory.getSharedInstance().getCategories()
for categorie in categories:
	print categorie
	functions = DefaultFunctionFactory.getSharedInstance().getFunctionsInCategory(categorie)
	print functions
	for f in functions:
		print DefaultFunctionFactory.getSharedInstance().getFunction(f).getArgDocString()
return
Type Casting
[toStr, toInt, toFont, toLong, toDate, toFloat, toColor, toBorder, toInteger, toDouble, toBoolean, toString, toDataSet]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
value, [failover]
Advanced
[qualifiedValue, columnRearrange, columnRename, forceQuality, tag, runScript, sortDataset]
value, level, [subcode], [diagnostic]
dataset, col...
dataset, newName...
