Ignition 8 mvn install command
I’m developing a module for Ignition 8 and using a docker container as my Ignition 8 server. The error message I’m getting is:
Could not post the module to the Gateway.: Could not post module to gateway. Error writing to server -> [Help 1]
I have included the module upload argument into the gateway config:
-Dia.developer.moduleupload=true
I can also see the servlet is active from my web browser at:
http://localhost:8088/system/DeveloperModuleLoadingServlet
I’m using v1.1.0 for the ignition-maven-plugin. Anything else I’m missing or need to check?
if you re-run maven with the -e switch what does the full stack trace say?
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:215)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:156)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:148)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:117)
    at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject (LifecycleModuleBuilder.java:81)
    at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build (SingleThreadedBuilder.java:56)
    at org.apache.maven.lifecycle.internal.LifecycleStarter.execute (LifecycleStarter.java:128)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:305)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:192)
    at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:105)
    at org.apache.maven.cli.MavenCli.execute (MavenCli.java:957)
    at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:289)
    at org.apache.maven.cli.MavenCli.main (MavenCli.java:193)
    at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0 (Native Method)
    at jdk.internal.reflect.NativeMethodAccessorImpl.invoke (NativeMethodAccessorImpl.java:62)
    at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke (DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke (Method.java:564)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
    at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
    at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
Caused by: org.apache.maven.plugin.MojoExecutionException: Could not post the module to the Gateway.
    at com.inductiveautomation.ignitionsdk.PostModuleMojo.execute (PostModuleMojo.java:73)
    at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo (DefaultBuildPluginManager.java:137)
    at org.apache.maven.lifecycle.internal.MojoExecutor.execute (MojoExecutor.java:210)
Caused by: org.apache.maven.plugin.MojoExecutionException: Could not post module to gateway.
    at com.inductiveautomation.ignitionsdk.PostModuleMojo.postModuleToGateway (PostModuleMojo.java:114)
    at com.inductiveautomation.ignitionsdk.PostModuleMojo.execute (PostModuleMojo.java:71)
Caused by: java.io.IOException: Error writing to server
    at sun.net.www.protocol.http.HttpURLConnection.writeRequests (HttpURLConnection.java:719)
    at sun.net.www.protocol.http.HttpURLConnection.writeRequests (HttpURLConnection.java:731)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream0 (HttpURLConnection.java:1616)
    at sun.net.www.protocol.http.HttpURLConnection.getInputStream (HttpURLConnection.java:1523)
    at com.inductiveautomation.ignitionsdk.PostModuleMojo.postModuleToGateway (PostModuleMojo.java:105)
Hmm. Don’t know, looks like some kind of network problem:
Obvious guess would be something to do with it running in a docker container but I don’t know where to start looking. Firewall or AV maybe? Not sure why your browser resolves it without issue, though.
I just added the debug logger on your plugin there and I think this is failing on line 105 of your PostModuleMojo class when we’re trying to read back whatever the gateway reply is… I was able to see the “Successfully wrote to gateway” message.
        BufferedReader br = new BufferedReader(new InputStreamReader(urlConn.getInputStream()));
        String line = null;
        while ((line = br.readLine()) != null) {
            getLog().debug(line);
Maybe you can capture the traffic from the plugin vs the browser in Wireshark and we’ll see a difference.
Yup good idea - here’s a link to my wireshark capture:
I don’t think the HttpURLConnection used by the plugin is configured to follow redirects.
Feel free to make that change and submit a PR. You can mvn install the modified plugin and use it locally until we release it.
Right will do thank you Kevin :+1:
I think the URL in the plugin could be updated as well: it’s now http://localhost:8088/system/DeveloperModuleLoadingServlet and not http://localhost:8088/main/system/DeveloperModuleLoadingServlet, which is where the redirect is coming from.
Did this ever get merged into the plugin? Having the exact same issue with a gateway running in a local docker container on port 80, have tried
<gatewayAddress>http://localhost:80</gatewayAddress>
and
<gatewayAddress>http://localhost</gatewayAddress>
to no avail
No it’s sitting in a PR if you want to build yourself a copy: https://github.com/inductiveautomation/ignition-maven-plugin/pull/4
He kept adding commits and then I forgot all about it.
Yeah sorry I’m all done playing if you’d like to merge it. I was playing with adding another maven goal to sign the module but I decided that was too much crap in one pull request (and it was a dumb idea anyway).
@Kevin.Herron is there anyway we can publish this to your maven repository?
I’ll try to do a release of the plugin today.
Okay, version 1.2.0 of the plugin is now published to Maven Central. Should be available soon if not already.
Thanks Kevin!
