I have a reporting sql query that saves as a PDF via a button on screen(Vision); the time range is changed by component on screen as well. I want to implement a dropdown to say either sort by ascending or descending order. I can build the query manually but I can not pass the option in from the window the same way I am doing the StartDate/EndDate. The SQL query doesnt like any form of “asc” or “desc” that I try to pass to it. Please help, much appreciated.
Please show your query.
Ascending vs Descending in a query’s ORDER BY clause would be considered part of the query structure, not data. You must use curly-brace string substitution, not a ‘?’ placeholder, for structure.
Is your query a ‘SQL Query’ or a ‘Basic SQL Query’ type? Only the latter allows query structure subsitution, I believe.
From some google, it seems like a CASE statement might be valid for the ORDER BY clause; something like
ORDER BY
CASE WHEN 'ASC' THEN SortColumn ELSE '' END ASC,
CASE WHEN 'DESC' THEN SortColumn ELSE '' END DESC
Ramifications for performance may be dramatic, and in general this isn’t a “recommended” approach.
Another possibility would be to always query ascending, but use a script data source to reverse it conditionally.
it is a SQL query and the start/end dates are working fine.
Or you could convert to a Named Query–those permit both types of substitution.
