Hi all.
I have ignition 8.0 installed on VMWare version 15 with NAT configuration between VM and host.
I have tried to establish two connections with the database servers that I have in the Host (SQL Server and MySQL Server)
With SQL Server I have no problem establishing the connection it works the first time.
However, with MySQL I have not been able to connect to the server (this server is in the default configuration user: root/port: 3306)
In the ignition gateway, I already have the connector to the MySQL database installed but even though I try to establish a connection the state always remains in failure
MySQL Configuration
User: root
port: 3306
