I am working on Ignition 8 using MySQL 8 with an older jar version, so SQL wasn’t working. Before figuring out I needed the latest jar version I did a restart of my system. When windows came back up I am unable to get to the web service. It just spins saying Gateway starting. Looking into the wrapper log:
From other posts it sounds like it could be because of the old jar version. I have downloaded the latest however the instructions i have seen on here talks about going to the GW configuration to install the new jar. Unfortunately I can not get into the GW since all it does is spin. If it is the jar that is the root cause, how can I install it so I can get into the GW?
If not being able to get into the GW is NOT due to the jar, does anyone have any other ideas.
Thanks,
Al
