dear gentlemen,
I was able to connect to Control logix ethernet via ignition’s OPC-UA,
but i am unableto browse tags from the opc server quick client view,
i can see the global (folder under the cpu) but not the tags,
allenbradley
please send guide us…
regards,
abdul
Try browsing in the Ignition designer. The Quick Client doesn’t work really well with large numbers of tags.
I have tried, but not working aswell,
could you please suggest me some alternative solution…
waiting for ur reply
Well, do you have any errors in the console in the Ignition Gateway config page?
no errors,
browse pending
protocol EIP
Unfortunately, you are going to have to call our tech support at (800) 266-7798 so we can see what is going on.
That is fine. You could be running into a bug that we should look at.
