Hello guys.
Did anyone of you worked with Siemens Sicam P855 Power Quality Analyzer with special encoding register Values ? I can provide more information.
Hello Again , i manage to read those 64bit values with special encoding. If you ever need to read the Specific power Analyzer dont hesitate to reply here, so i can help you out.
Feel free to explain now, so if someone looks for it a year from now, they'll find this answer immediately.
Hi Phil you are right , i need to run a simulation test with a plc to check the value range that it wont be affected, if its ok i will post the solution here.
This is a 64bit Register value for measuring KWh which is a long number. I dont have any other way of reading the value with another modbus tool or app , so i have to generate some similar values to a plc with python and read those values from 4 registers. If its ok i will show how to adjust the settings.
