Ignition as a Service
Hello all,
I have installed Ignition on my Raspberry Pi running Raspbian and it is working great.
I have set it to where it auto boots Ignition whenever the Pi is powered on, but am now wanting to set Ignition as a service instead of just running it.
I have created a unit file and the service itself says that it is fine, but the Ignition Gateway nevers opens.
Are there some parameters in the unit file that anyone knows that I need to add?
Running ignition.sh install should automatically generate a service/systemd/init.d/etc file to run Ignition as a service. On raspbian you could then (I’m pretty sure) systemctl enable ignition or systemctl enable "Ignition Gateway" until we fix the service name.
Thank you, this is exactly what I was looking for!
