I have installed and manually run smoothly Ignition on latest Mountain Lion Server.
Also copied *.plist file to StartUpItems library.
Problem now is that I have to use sudo su to start Ignition gateway and automatic startup fails because permission denied.
Maybe I am lonely OSX user but if somebody else is also “wise” enough to use OSX in Ignition platform, here is guide how to install Ignition to start automatically and still keep permissions safe level.
This works now only when using automatic login, there is some permission problems with wrapper if not using autologin?
I am using currently Mountain Lion 10.8.1
Older version has small differencies but I am quite sure that this works also older osx versions.
Load ignition-osx.zip from Inductive Automation downloads section.
Open terminal from applications
Go download folder, so where you downloaded igniton-osx.zip, normally it goes under account folder Downloads cd /Users/“accname”/Downloads
Give sudo su and password sudo su
unzip ignition.osx.zip and make directory unzip -d /usr/local/ignition ignition-osx.zip
6.Go ignition folder cd /usr/local/ignition
Give executable rights chmod +x ignition.sh chmod +x ignition-gateway chmod +x gcu.sh
Make new dir for launch alias mkdir /usr/local/bin
Go new dir cd /usr/local/bin/
Make link ln -s /usr/local/ignition/ignition.sh ignition
Go back to ignition folder cd /usr/local/ignition/
Copy startup list in daemons folder cp com.inductiveautomation.com.ignition.plist /System/Library/LaunchDaemons/
Make plist load in startup, this will also start service right away and keep running always launchctl load -w /System/Library/LaunchDaemons/com.inductiveautomation.com.ignition.plist
If you want to turn off your Mac you should stop service first from terminal. sudo ignition stop
You can also manually restart,stop or start gateway sudo ignition restart sudo ignition stop sudo ignition start
ok, it looks like something is not quite working when the computer starts. When it is working correctly I see an application called org.tanukisoftware.wrapper.WrapperSimpleApp in the dock. I’m assuming that this is the gateway running, but perhaps it is something else. It does always show up when I go to terminal and start the gateway.
On initial boot of the computer this file is not there and the gateway is running but not correctly. I cannot connect to it with anything (local or remote). If I go to terminal and “sudo ignition restart” it does stop ignition and then restart and the strange app shows up in the dock and then everything seems to work correctly from that point on.
I really do need to find a way to get the gateway to start automatically, or I need to have an executable on the desktop that will restart the gateway. I have some operators who will not be able to restart this without me and I do not want to get calls at 2am because the power dipped for a few seconds and the gateway did not restart automatically.
The org.tanukisoftware.wrapper.WrapperSimpleApp is a executable that runs the Ignition gateway. I was able to successfully run vahterto’s instructions successfully on a Macbook Pro running OSX 10.8.4 (nice instructions by the way!) and the gateway starts without errors upon machine startup. So it’s hard to say why your gateway doesn’t automatically start. Maybe the ignition folder doesn’t have the correct permissions, or something like that. Is there anything interesting in logs/wrapper.log?
well, technically it does start. It just does not allow for any client connections. After booting, I can run the sudo ignition start and I get “Ignition Gateway is already running.” I can restart with the restart command or the stop command followed by the start command and both get it running correctly. Not sure why it does not run at boot. No errors in the logs that I can find. I’m only a few miles from Folsom…should I bring it over?
OK, I was able to replicate the client launching problem on our Macbook here. The good news is that the new native client launchers are able to work around the problem. The native launchers also have the advantage of being able to retry contacting the gateway forever until it finally finishes startup and responds. So if your box dies, and you have added a client launch to run at startup, everything should start up again after a few minutes.
